3 members (Gdads51, Bill Hanlon, TexasJim50), 329 guests, and 6 robots.
Topics128,162
Posts1,057,068
Members48,463
Anyone know where to find one - new or used? Get plans to fabricate?
Haven't see a pic of one (just the carrier w/o the tire) mounted on a 3100 or 3600, but it looks like on the 3600 it would go between the two vertical braces?
Post an ad in the Parts Wanted forum in the Swap Meet.
There is no need to indicate "stepside" because there was only one type of pickup side in 1953.
State that you want a 1953 3604 side mounted spare wheel carrier. That style was only available in 1953. In 1954, the style of the bed changed, so that side mounted carrier is a little different.
Maybe someone will post a photo of the 3604 with the side mounted wheel carrier (and a picture of the bracket/basket/mount). Unlike on the 3104, there was no need to have a dimple in the fender on a 3600.
Thanks for the replies - it's a good start. I should mention that I'm in the process of some changes & the truck will soon have 5 bolt pattern wheels. I mention this as I know (if I find one) I will have to change the bolt pattern from the 8 bolt.
This pic (not my truck - photo from Ebay)is the way I see this mounted:
http://i36.photobucket.com/albums/e22/riverwork/Chevy49/Ser/sidemount.jpg
I've got one of those new fangled 1965 models, I built my own carrier.
It's hell-for-stout, and it's totally hidden with the tire in place.
It also stiffens up the bed side considerably because it ties the stake pocket into the bed rail.
Here's a couple photo links:
http://i645.photobucket.com/albums/...1530103882008S600x600Q85_zps7ef52950.jpg
http://i645.photobucket.com/albums/...20Carrier%20Oct%202009/2009_10200015.jpg
And a link to the drawings I created:
http://i645.photobucket.com/albums/...202009/TireMountSheetOne_zpsb9d1aae5.jpg
http://i645.photobucket.com/albums/...202009/TireMountSheetTwo_zps7206b931.jpg
http://i645.photobucket.com/albums/...2009/TireMountSheetThree_zps9c2a016a.jpg
I hope that helps. If nothing else maybe it'll get some ideas floating around in your head on how you too can build your own.
Thank for everyone's help. Got a 54' carrier on the way. Have now touched base with a couple folks who have used on their AD 3600's. Couple small mods will be needed plus some attention to the stress on the bed sheet metal.
If I were under construction ( it's already restored) , I would have seriously considered a variation on John's to fit an AD. Simple, robust & hidden. I like.
...here's one I haven't seen yet (second picture down)...looks low given the running board:
http://67-72chevytrucks.com/vboard/showthread.php?t=597180
Yeah.. that's not oem... not by a long shot. thumbs_up
For sure, not OEM, but not a bad design. Looks like it held up without damaging the bed side. A little cleaner design would have some possibilities....
