1 members (delky),
74
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Were can i find the correct guage wire for my truck 55...I have looked at auto zone checker ect...I even looked in ....somebody shoot me WALMART....mIKE g
HURRY UP AND WAIT 55 235 3/4
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "correct"? the wiring diagrams in the shop manuals show the ga used for a particular place, - these trucks used 12, 14, 16, 18, 20 ga depending on the exact location and expected current flow - any auto supply should have spools of all of those sizes, but none will know anything about "correct"
Bill | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | well...thanks Bill, I guess they (checker,auto zone) are always out of what I need when i go there, all these auto stores usually only have those little pakets of wire,and i can never find 12 G. I will go back and ask Questions next time. Mike g
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mike G. My local ACE hardware store has spools-o-plenty of wire that is sold by the foot. Other than insulation type, wire is wire. The wire found at the hardware store will probably be THHN or THWN which is the Cadillac of wire insulation. Below is a link to a site with good basic wire info. Good luck. http://www.crowbarelectricalparts.com/Specifications.htm Stuart | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Thanks Stuart, I forgot about ace Hard.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Not to cross swords with Atomarc but I use a SAE approved (SAE-J1128) wire that called cross-linked polyethylene. Buy it online at a place called "Del City" in 100' rolls. Keep it on hand to help my rod buddies when they need wiring help. Del City also sells high temperature wire loom material which I also purchased after melting some cheesie stuff I picked up at a local car show.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | beltfed, I agree with your choice. The wires I have used for my rewire jobs were 'procured' from my job. Although these are quality wires, they are not the soft, flexible wires commonly associated with automotive use and don't carry any SAE approval. I will check Del City out...thanks. Stuart | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | By the way Mike, to find out what the correct ga. is on any given circuit go to "Old Online Chevy Manuals", under Tech Tips in this forum. There's a wiring diagram for '55 trucks there. | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Hey Guys thanks..I started this project a year ago...and to be honest it took me a while to not substitude if I do not have the correct product. I did some regrouping this winter,I acually walked away from my resto for the winter..It was that bad, now i am starting something and acually finishing what i started before moving on. I was lucky..the 1955 shop manual came with my truck,Gudda blow up the pictures though..Is It possable..and feesable to rewire my truck 1 wire at a time...I know you guys are laughing at me right now,finish laughing and give me an answer.M/G
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ve done all my wireing one wire at a time but I think next time I do a large wireing job I will look into one of the universal harness kits. Time you by a lot of spools of wire plus a fuse block & materials it will be cheaper & save a lot of time. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Well that answers my Question.I know I am headed in that direction, I removed my iner fenders and started inspecting the wires...they are pretty brittle. Oh well...another job to do.I also removed my rear fenders today...and i dont want to talk about it.........
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | By and by...those wiring harnesses are neat. They lable every few inches where the wire goes which makes it easier. I purchased one for the day I explode my car to do other work. No butt splices and the same color from one end to the other...it don't get any better than that.
| | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Labled every few inches..Now Thats for me..Electricle work for idiots..Let me ask a question. I have looked at all the wireing involved in my 55..there is nothing fancy,no air ect...there really is not a hell of a lot of wires.I do not have any fuses..or fuse box,that I see some of bolters talk about,every # matches on this truck,nothing is updated, It is exactly the same as it came off the esmbly line,it still has those dam split rims. Will that make my wiring job easier? Or will I be adding anything with a new Harness.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Mike - the standard minimal wiring on these trucks is very simple, and a good repro harness will already be physically shaped exactly how it fits in place, along with the correct color coded wires to match the shop manual wiring diagram - piece of cake, only "choice" is if you get the harness for original generator setup or one for switching to an alternator - doing it one wire at a time yourself is the way to end up with a rats nest of stuff under the dash that nobody can figure out later
Bill | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I'm rewiring mine one wire at a time right now, except I'm replacing less than half the wires, only the bad ones. I think that as long as you approach it in a methodical manner, you can end up with a correctly wired and neat installation. I've got the mini rats nest that was under the dash all sorted out and labeled and plan to start actually installing wire tonight.
I'm dreading the rat's nest that I need to go through in my wife's project car.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | Hi, Not wanting to hijack the thread but just ask a question. I have my 53 apart, and now is the time to do the rewiring, I know I want to do just the reproduction type harness, not really an upgrade, based on a lot of reading here I decided to leave the truck 6V nice and simple. There was a harness in Chevy Duty, and I was looking at RI Wire Services. Any suggestions or recommendations are appreciated. Mike My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
| | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I think I will do the Harness..someone was under my dash at one time...seems some of the wires start with the correct color and Guage and then...you know..the color changes and so do some of the Guage...it still starts and runs great,but I want it to be correct,so i can work on it.I really took an long look at all the wiring..they are extremly brittle,most of them coming out of the fire wall were covered in grease, and the wiring hooked to the fram under,are wraped in electrical tape...who knows what shape they are in,I still Have the genorator..should I switch it over..
| | | | | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | I did a search on the forum and it seems if you want to go the upgrade route there are numerous choices and lots of opinions. I want to stay pretty stock, and the choice is big bucks for the cloth braided wire which is as original, or the consensus was the wire harness from Chevy Duty - mine priced at $149 for the 53-54. Here is the link for the 1955 - http://www.classicparts.com/prodinfo.asp?number=52-027 My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
| | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Thanks alot for the help...M/G
