7 members (Hanks custodian, Steelonsteel, Gdads51, TUTS 59, Mike Burns, Wayne67vert, 1 invisible), 88 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#1005085 02/07/2014 5:39 AM
Howdy folks....I'd like to use a tachometer designed for a diesel engine on my 235 chev. Diesel tachs only read in the 4000 rpm full scale region which ,to me, suits a 235 much better than any of the 8000 rpm gas units.
From looking at many units on ebay, it seems that diesel tachs run off some type of sensor on the alternator. I'm using a generator.....so does anybody have any experience / knowledge of diesel tach senders modified for generators ?
thanks all
It would be helpful know the make and model of your engine, some of them have a take off off the flywheel housing
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
dieseasel...... the engine is a '56 235 GAS with a generator.
why not consider a low-rpm tach for a gas engine? seems much easier than trying to adapt a diesel tach. here's an example:
4000 rpm tachometer
tomctomc..... ya, way better plan ! Thanks for the idea.
les
