10 members (chevy51truck, Gdads51, Phak1, 52Carl, KEVINSKI, Woodcmiami, Peggy M, Wickedbass, Tinker5, 1 invisible),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Would like to buy a generator for my garage at the cottage( hopefully I will get it built this year}Was thinking I could use the generator to power the garage. Just for lights and plugs and to use as a backup for my cottage.HF has one on sale, 8750 peak/7000 running. Is that overkill? They have a 5000 running on for 450., the 7000 is 600.The 150.00 difference isn't going to break me,Your thoughts please, guys and gals.  | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I have a 5000w Honda, it will power quite a bit. An electrician will tell you to add up whatever you want to run and take it from there. Are they all gas? Diesels usually are cheaper to run and the fuel won't go stale if it sits over the winter. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Go with the 7K generator- - - -I don't know of anyone who ever wished he had bought a smaller unit, but I know quite a few guys with RV generators who would love to have a couple of extra Kwatts when several appliances are running. Jerry
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I went the other direction and got a smallish one. Honda EU2000i. This is for house backup. I put in a transfer box last spring so it is easy to just plug it in then switch on whichever circuits I want to use. Luckily I haven't needed it, so can't give any report on how it works over time. It will run everything in the house except 220v stuff. I have 10 circuits so I can choose what combination of things to run. I wanted something quiet that only sipped the gas. As stated above, you have to do the math on what you want to run simultaneously.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Check the ratings. Some of those "off-brand" generators are generous with their labels. And they are usually noisier, too! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Power out protection: http://www.pbase.com/dennygraham/generators7K watt gas generator, which I run the house off of when the power goes down, which happens often. Power a few lights, TV's, computers and router, Sump and the well pump which is 220v. Been out here since 2012, ran it a half dozen times for several hours each time and haven't added or changed fuel yet. It's a Coleman with a Briggs & Stratton Vanguard V-twin engine and it's noisy, Honda is no doubt the quietest but price is three times as much. But this is a back up, not used for full time power as it appears your looking for Dicky. dg
Denny G Sandwich, IL
| | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | I'd go for one with at least one 220v, 30amp output, especially for a garage. I've used mine several times for a temp 220v service until I could run a dedicated circuit from my panel. | | |
