0 members (),
75
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 40 | I am converting from 6v to 12v and my gas gauge wasn't working before the change over...can some one tell me what the matching specs are on the Gauge & Sending Unit.
Also can the gauge be set up to run as a 12 volt without having to use a step-down transformer? If it has to be sent out...please let me know who would do this.
Thank you all.
John | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Lots of posts on just this issue. Most recommend a "Runtz" inline with the gauge to keep it safe at 12 volts. Some gauges can be fixed and some cannot. The gauge is matched with a 30 ohm sender and this is true for both 6 volt and 12 volt gauges. You should check the wire and connections before you pull the dash apart. You might just have a bad wire. Do a search for fuel gauge and you will get a lot of good information. Good luck and have fun. Let us know how you fare.
Steve H
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | John, Thanks for using your name. Always nice to address a person by a real name. Jim Carter either has or does rebuilding of gauges. Contact him at Phone: 1.800.842.1913 to see if he can help you or direct you to someone who can. Web site: http://www.oldchevytrucks.com/Harold
Harold Is a restoration ever finished? | | |
