3 members (wilbur53, Youngin' Tut 59, delwrench), 90 guests, and 2 robots.
Topics128,174
Posts1,057,048
Members48,458
I am contemplating on buying a'50 Chevy half ton p/u and the guy will throw in a '75 silverado so I can transfer the suspensions over. Is this possible? would't the '75 be too wide?
Any info or ideas would be greatly appreciated.
Thanks, Gabe :confused:
South Texas Rod and Custom
Home of "The Goonrod"
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
Quote
Originally posted by Hedgehog:
Yes to both.
Thanks for the info Hedgehog.
I appreciate the link to your project site it will be very helpful.
TD
There are other ways to perform this swap. The link above shows how to narrow the crossmember, which addresses the width problem. Other's have made spacers to mount the crossmember, using about 1/2-inch on each side, and used the same spacers to mount the steering components.
Using spacers it does end up pretty wide unless you use wheels with lots of negative backspace.
Another common IFS solution is to use a Camaro or Chevelle subframe. These are too wide also, and I've seen one guy who widened the front fenders to get a wide low look and to cover his front tires.
