1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1003273 01/31/2014 5:09 PM
need a wiring guru. 78 chev impala engine wiring and fuse panel. using a 64 chevy 11 dash. need to convert from 78 dash wiring to 64 chevy 11 instument panels. clear as mud ? thanks Doug
Did you have a question? Not sure what you are asking.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
I think you might be better off going to a vendor and buying a new universal harness and start off fresh.
thanx for the reply,s. this truck is a home built, from ground up. read--no vender parts. All used parts- 80 camaro, 77 pontiac, 77 impala,90 s10, 74 vette, harley, etc,budget,budget,budget. thanx guys Don
I'd start with wiring diagrams for the 78 and 64. Then hope none of the sensors don't match the gauges. The universal wiring harness might be the ticket if the instruction are good.
Larry
I don't own a vehicle that isn't old enough to drink.
Not trying to be a smartarse but you are going to have so many splices and a cobbled up mess, your asking for a problem. You are better off using some fresh wire off a spool along with some fresh connectors. Not saying you can't use the old gauges and switches/sensors.
Not really sure what the problem is... One wire at s time, unplug (tag) from Impala and reconnect to same thing on ChevyII dash. You may have to change connectors...
On the dash side, I see it as easy. The problem could be if the 2 cars do not use similar sensors/senders..., such as fuel tank gauge, temp sensor...
This will take some time, but one wire at a time, it will easy...
'57 Chevy Suburban; '70 Chevy Impala.
