| | | Forums66 Topics128,078 Posts1,055,939 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 56 | I am going with a firewall mounted dual diaphram brake booster/master cylinder/prop/ valve combo because I need a modern split braking system as our truck is used every day and will no longer pass its yearly inspection with a single system master cylinder.
The kits are readily available but how do we handle the split master cylinder for the clutch slave? I need some type of separate clutch master cylinder to operate the slave. Is there is a retrofit unit people use with this modern brake booster system? thanks
1953 Chevrolet Handyman Wagon 36k 1938 Buick 38k 1947 Hudson Commodore 18k
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bigblack'74, the 1960 through 62 trucks which had air brakes used a single clutch master. I don't know how much room, if any, you would have in the stock location to mount a clutch master next to your booster/master cylinder. I think you will have to mount the clutch master more toward the middle of the firewall, and fabricate your own linkage to it, good luck with your project. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Make sure you are using a dual MC system for a 1-1/2 ton truck and not the kits that are sold everywhere for the 1/2 ton trucks...they have a smaller size bore. Be safe! Mike B  | | |
