1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#1003490 02/01/2014 1:12 PM
I am going with a firewall mounted dual diaphram brake booster/master cylinder/prop/ valve combo because I need a modern split braking system as our truck is used every day and will no longer pass its yearly inspection with a single system master cylinder.
The kits are readily available but how do we handle the split master cylinder for the clutch slave? I need some type of separate clutch master cylinder to operate the slave. Is there is a retrofit unit people use with this modern brake booster system? thanks
1953 Chevrolet Handyman Wagon 36k
1938 Buick 38k
1947 Hudson Commodore 18k
3B Offline
Hy bigblack'74, the 1960 through 62 trucks which had air brakes used a single clutch master. I don't know how much room, if any, you would have in the stock location to mount a clutch master next to your booster/master cylinder. I think you will have to mount the clutch master more toward the middle of the firewall, and fabricate your own linkage to it, good luck with your project.
Make sure you are using a dual MC system for a 1-1/2 ton truck and not the kits that are sold everywhere for the 1/2 ton trucks...they have a smaller size bore.
Be safe!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
