| | | Forums66 Topics128,196 Posts1,057,382 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 48 Junior Member | | Junior Member Joined: Dec 2006 Posts: 48 | I took the horns apart and the metal plate (diaphram ?) was rusted thru. Can I get this part?
Thanks as allways. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Go to swap meets and look for a similar horn to use for parts. If there's enough of it left to use for a pattern a good fab shop may be able to make you one. Another posibility is to look in Hemmings Motor News to see if there's someone rebuilding them.
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Tried to once myself. Could never find the replacement parts but that's before I learned to surf the web. Good luck.
