2 members (Guitplayer, 1 invisible), 174 guests, and 3 robots.
Topics128,196
Posts1,057,395
Members48,469
Junior Member
Junior Member
I took the horns apart and the metal plate (diaphram ?) was rusted thru. Can I get this part?
Thanks as allways.
Ex Hall Monitor
Ex Hall Monitor
Go to swap meets and look for a similar horn to use for parts. If there's enough of it left to use for a pattern a good fab shop may be able to make you one. Another posibility is to look in Hemmings Motor News to see if there's someone rebuilding them.
Tried to once myself. Could never find the replacement parts but that's before I learned to surf the web. Good luck.
