| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10035 02/28/2004 3:52 AM | Joined: Oct 2003 Posts: 54 Member | | Member Joined: Oct 2003 Posts: 54 | Has anybody ever ditched the side mounts for their radiator? I'm thinking about digging up a set of "U" shaped rubber mounts from a later model truck and building some custom brackets. I've had leak problems in the past, and now the entire side of the radiator is comming off. This may not be a big deal to most of you who only see street driving, but maxing out the suspension flex with this 4x4 really twists the frame where the radiator mounts, and is literally pulling the radiator apart. Right now, I've only got 4 bolts holding it in place (instead of 6), but it's still giving me troubles.
Any ideas? If I can get ahold of a camera, I'll post a few pics. | | |
#10036 02/29/2004 12:38 AM | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | If you're going to modify, why not go to a late-model crossflow radiator while you're at it? I had to do this when the radiator from my 59 carryall was stolen while the truck was stored in a tow-in lot. (It had broken down, and before I could recover it from the towing service, somebody helped himself to the radiator!) I used the lower mount assembly from a rubber-mounted crossflow radiator, and fabricated an upper hold-down assembly from sheet metal. It worked OK, including a cross-country trip from California to Tennessee, towing another vehicle. Jerry
#10037 02/29/2004 5:58 AM | Joined: Oct 2003 Posts: 54 Member | | Member Joined: Oct 2003 Posts: 54 | Yeah, a cross-flow radiator would be real nice, but this darn university likes to see their money (expensive education + not much work = not very much cash  ). grrrr. Do you have any pics of the way you mounted your radiator? I kinda have an idea of how I want to do it, but any other advice would be very helpful! | | |
#10038 02/29/2004 6:53 AM | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Hmmmm- - - - The old Carryall is out behind the barn, with several years' worth of blackberry vines grown up around it! If I can get to it soon, I'll send some pics!
"You might be a redneck if you cut your lawn and find a car!" Jeff Foxworthy
#10039 03/06/2004 4:25 AM | Joined: May 2003 Posts: 57 Member | | Member Joined: May 2003 Posts: 57 | I guess you have a big honkin X brace the front of that big rad hole?
65 C10 292/700R4 long fleet...Gettin closer by the day.
#10040 03/08/2004 12:17 AM | Joined: Oct 2003 Posts: 54 Member | | Member Joined: Oct 2003 Posts: 54 | Yep, sure do, but it still flexes way too much. Like I said, most people won't have this problem, because the do all street driving, but this old 4x4 was ment to be off road, so it sees it's share of time on the trails. I wonder of 1/2's have this problem, because they would have a much lighter suspension that would flex better, and take more stress off the frame. | | |
