Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (carbking, Shade Baby), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
I bought a parts truck, (1/2t. '48 pick-up) and it has the earlier trans with the lift reverse lever.
Is there anything special about these? Desirable? Hard to find?
Thanks, Bill
Don't you just hate the new guys! Lol
They are not synchromesh transmissions. The SM420 looks like the transmission you have but they are synchromesh. Rebuild kits are available for the SM420. I think you might have some difficulty finding rebuild parts with the older style (often referred to the 'crash box') transmission. You have to upshift differently and double clutch to downshift with the crash box to avoid grinding. Once you get the hang of it, they are fun to drive. (We were all new guys at some point!!)
It's a small world, but I wouldn't want to paint it.
1931-47 is the same basic trans.
They came with either open drive or torque tube, depending what it is out of.
My Blog
The old spur gear or sliding gear transmissions are like almost anything else that hasn't been produced in 70 years. If you need one, they are hard to find. It is usually easier or cheaper to find another one than to rebuild one that needs a lot of work. The bold pattern at the clutch housing is different than the SM420.
Hey Rusty,
I wasn't quite sure what to do with it. I didn't know they were non-syncro . I agree that it would be fun to drive one, I am shift lover. But, unless it was in a vehicle I wanted to keep original, I don't think I'll be using it for anything.
I sure appreciate your info. Still looking for that "good" Suburban to be fired up about.
Thanks, Bill
