2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | In pursuing leads to the mystery of my curved steering column connector, I discovered some threads in the archives of this page which answered all of my questions but one --how do you wire a three-prong flasher?? I have a flasher socket with black, red, and yellow wires. Because it was fused, I know the black wire goes to a constant hot feed, but what about the red and yellow ? | | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | Update. The color of the wires isn't important, it's the flasher terminal label. Through several hours of computer searching, I know the power feed is the X terminal. The other two are P and L. Several sources indicate the P terminal is to the pilot light, which I believe is the single lite that flashes on a Signal Stat unit, but I don't have one of those. Where do the P and L wires go to or come from? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Russell,
Here's guess (from a '54 wiring diagram):
P: to the indicator light (same bulb for right and left - one indicator bulb) X: power lead L: to the directional lever switch
Maybe someone who has hooked one up will confirm or correct this.
Tim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You got it. I just did one & that,s how it goes. The socket is the same as a headlight. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i know the socket is not labeled, so i assume the flasher is. what is the standard wiring of the prongs????? as you look at the three prongs w/ the center one @ the 12 o'clock position: :confused: X-P-L which is what ~~~ the center spade is ?? the spade to the rigth is? the spade to the leftt is? knowing this standard many of us can wire &/or prewire our trucks (I'm at that time frame), w/o having it all together. FYI if you use a three prong oil pressure switch... the headlight socket works for that also.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | Tim- thanks for the tips. L goes to the turn signal lever, but P ?? The wiring diagram for my steering column (actually for the whole 67-72 truck) shows two leads coming from the curved connector for each of the front turn signals. One goes to the front light, and the other goes to the indicator light on the dash (light blue to right and dark blue to left). Do I splice two wires together from P terminal, and if so, how are they connected to the two indicator lights so they flash correctly?? It just occurred to me that perhaps I should have only a two prong flasher for this set-up. That is what is shown on a diagram from 50chevy.freeservers. | | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | Jim and Caroline-- The prongs are labeled on the flasher. P is at the top, X is to the left, L is to the right | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have ind. lamps for each side you dont need the P term. or you can use a 2 prong flasher. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | Thanks for the tips, Tim and Wrenchbender. I am wired, and can report that the hazard lights and brake lights work fine, but not the turn signals. I'll tinker on them today, and report findings or questions later. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a thought...I added isolated LED turn signals to the rear of my 54 truck...went with a new 3 prong electronic flasher. Added a conventional 12v bed roll light tied into the turn signal circuit. Am using an add-on turn signal column mounted unit.
Couldn't get the little indicator lights in the column unit to flash, so I tied in a couple little buzzers. Today I hooked up a non-electronic flasher....same position of wires on the flasher and the indicator lights work!!!
I can't explain why it works, but it sure is great having everything working as advertised. Might be worth a try if you're having problems getting your add-on turn signal unit to work properly. Hope this might help.
Dave | | |
