2 members (TUTS 59, KingG), 106 guests, and 3 robots.
Topics128,026
Posts1,055,400
Members48,422
#10031 08/16/2004 2:06 AM
Junior Member
Junior Member
Is there a way to replace the motor mounts without pulling the engine?
I think my mounts are shot. The engine seems to "twist" if you look at the starter pedal in relation to the toe pan hole while under hard acceleration in 2nd gear. What about the trans mounts? Can I replace engine and or trans mounts by jacking up the engine/trans enough to get clearance without using an engine lift and disconnecting the trans?
Thanks!
#10032 08/16/2004 3:56 AM
Putting a jack under the engine will work the best, or else an engine hoist. You might not have tons of room to take out the old ones, but that depends on what year you own.
55 2 dr 210- after college project
56 2 dr 210- after '55 project
"D'oh"
#10033 08/16/2004 9:34 PM
The gm shop manual shows what to do. I recommend going to one of the aftermartket dealers and buying one. Best tool in the toolbox.
Fred
52 3600
69 C-10
#10034 08/18/2004 2:09 PM
Junior Member
Junior Member
Without a hoist, I'll need to jack it up from below.
Where should I put the jack on the engine without damaging anything?
Thanks!
