3 members (hardshell, klhansen, ShopRag), 44 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#100281 04/10/2007 4:23 PM
I'm finishing up my a/c install in my 54-3100 and have added a pusher fan for those times when I need to suppliment my belt driven fan. Will operate it off a toggle switch in lieu of a trinary switch.
Been looking at the usual plasic-cased relays and double relay setups for fans, and sure would like to find a metal relay that could be used for extended periods of time without cooking.
I've considered an old style metal horn relay but am hoping someone will have a better idea. Don't know if they would handle the extended time under power. I'm using the plastic bosch-style relays on my headlights but just want something that is a bit more ruggedfor the 14" fan. Any suggestions you might have would sure be appreciated.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#100282 04/10/2007 4:38 PM
Dave,
The traditional automotive relay can stay energized for eons and not vaporize. If the contact rating of the relay is adequate for the draw of your pusher fan, the relay could stay latched for years and not suffer any self destruction.
Stuart
#100283 04/10/2007 4:57 PM
RV shops have continuous used solonoids[sp?]generally used on two battery setups.they can be on all day and won't be a problem
#100284 04/10/2007 9:18 PM
Riding in the Passing Lane
Those little relays they have out now are pretty reliable. New vehicles use them on fuel pumps & fans all the time. What about a high blower relay used to be on all the GM cars back in the 60,s & 70,s. They were made for continuos duty at high amps.
1972 Chevy c10 Cheyenne Super
#100285 04/11/2007 3:28 AM
Thanks guys...good suggestions....once again http://www.RockAuto.com came through....68 Caprice 396 blower motor relay...$6.89. All metal case and it can be modified with small machine screws to secure the terminals. I don't like spade ends on high draw stuff!!!
Rock Auto let's you dig up an application and #'s so the local parts suppliers don't have a nervous breakdown.
Dave
#100286 04/11/2007 3:38 AM
Just a little thought you might check on. Several radiator shops say not to put a pusher/puller fan combo on your radiator. They say it creats a votex at the radiator and causes less air to flow not more. You might check it out.
#100287 04/11/2007 4:38 AM
I've also heard of this potential problem. I'm going to run it directly off a manual switch instead of off a trinary and will use it only when I know I'm going to be puttzing along in a cruise or idling for extended periods of time.
Hopefully, it's location in front of the radiator won't prove to restrict too much airflow at normal driving speeds. Time will tell! Thanks for your comment.
Dave cool
