0 members (),
230
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | I have seen a kit for gas pedal linkage if you use fenton headers on the 235. I have seen threads where people have had trouble with stock linkage after installing fenton headers. It includes all brackets springs and connecting rod to pedal for 65.00 Good choice or any alternative ideas. Paul | | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I used 1/4 inch rod from home depot, stuck it in a vise and bent it myself to get around my headers. I don't think the springs and rod came up to 65.00 plus shipping. What they think you need and what you see you need might be 2 different things. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Agree with Elmer. Make it your self. It's ez. For cotter pin insert if you use them, I flattened the rod slightly on one side to have a good surface to drill.
Drew
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | If you want to get real fancy run a die on the ends of the 1/4" rod and install throttle ball joints.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I installed a 235 with Fenton exhaust last spring, I used the old stock linkage, cut it , removed a short section,rewelded the remaining part reformed slightly the curve and reinstalled. It works fine, No Fancy kit costing How Much? Jerry Jerry
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I installed Fenton headers with an Offenhauser dual carb manifold.
The linkage for the dual carbs has a tab for the original throttle rod.
Just put it in the vice and made about 3 jogs to fit between the new manifolds. works fine.
