| | | Forums66 Topics128,152 Posts1,057,012 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | I just finished the removable floor panel of my 41', painting and replacing battery and master cylinder access covers...when I noticed a 2 inch or so round hole in the center rear of the panel - very close to the rear edge. So what is it for? Should it also get a cover?
| | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | As far as I know, this hole is open and was to stick your finger in to lift up the floorboard. I have a number of 1937-1940 GM trucks and they all have this open hole. | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | I was thinking that but seems there should be a cover or plug of some kind versus an opening to All the elements. I think I'll try to find a rubber plug to fit it | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I don't know for sure, but I think it was made to be as alkay3 says and was left open. I never thought much about it. I don't think the designers back then sweat the small stuff. What's a bit of fumes going to do to you? But they do have one over the master cylinder. It is a bit bigger though. Farmone, let us know what you come up with.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I think the finger hole is just covered with the rubber floor mat. I have never seen a part number for a plug. | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | Two possible solutions; the first I've implemented. I trimmed a cap off an Ice Mountain gallon container - see Photo Bucket pics, along with one pic for the extra hole under the gas tank. I think that one came off a 5 gallon HDepot paint container - no trimming required! Add a touch of caulk to the rim and you're good to go. I'm still working on getting part numbers for correct size rubber plugs used in several places on my brother's Mustang - designed just for weather sealing access holes in the body. I know they make them - just have to get the part numbers. But given the location on my 41 and the frequency of need to access, can't beat this freebie application. Hope this link works - not my strong suite! http://s767.photobucket.com/user/jtfarm1/library/Josh%201941?sort=3&page=1
| | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | Found a website to buy rubber plugs for just about any size hole you have within normal manufacturing of your truck. Also has a number of items for restoration 47-72' - be sure to browse the entire site. These plugs are nice for weather seal fit; squeeze and pop in/out of hole, $2-$4 each with free shipping and no min order. http://www.rubbertherightway.com/ | | |
