| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10025 01/09/2005 9:05 PM | Joined: Jan 2005 Posts: 52 Member | | Member Joined: Jan 2005 Posts: 52 | What gasoline octane should be used for a 1946 1/2 ton with a 216 Engine. Should octane boosters be added to prevent valve and valve seat problems? This engine is all original and smokes a little bit and has not run since 1986. | | |
#10026 01/09/2005 9:48 PM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Never ran a 216 but I would say unleaded regular is not a problem. If it pings then the timing is probably not right or too much buildup on the pistons causing hot spots. Doubt there could be enough build up to raise compressen that much. Valve wear with unleaded isn't much of a problem unless you really press an engine. However, when it comes time to do head work definitely go the hard seat route. Someone else might comment on what valve guides are available when redoing the head on one of these. Dennis
40 Chevy 1/2 ton
#10027 01/10/2005 1:22 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I ran my old 235 on the lowest octane (87) figuring I would rebuild the head if it had valve problems. I put in a 261, instead.
My engine man rebuilt an 848 head for the 261 with hardened seats. He said you only need the seats or the valves hardened, not both. He's pretty good but is this correct? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#10028 01/10/2005 3:10 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | If you don't plan on running the wheels off your truck, you will probably redo the head (as in change the valve seats when you do the rebuild) before you have a problem with no lead fuel.
By the way....what is the story behind your truck. Your truck looks like a pretty nice looking ride. | | |
#10029 01/10/2005 3:43 AM | Joined: Jan 2005 Posts: 52 Member | | Member Joined: Jan 2005 Posts: 52 | The truck actually belongs to my daughters boyfriend Eric Slachter. Eric inhereted the truck after his father passed away in 1986 and the truck has been sitting ever since. Eric's father obtained the truck in a trade for work that was done instead of money. The truck has had a Northern Hillbilly (Yooper) restoration job done to it and was not finished. There are a lot of sins and boogers done to this truck and Eric wants to get it running for this summer and do a complete restoration job back to original next year. The truck has all good solid steel in it with only one missing steel part and that is the floor board. Since I am retired with a lot of time on my hands (HA) eric had me bring the truck over to my place and wants me to work on it. The truck has been stored in his mothers barn all this time and is really in good shape. We got the engine running at christmas time and it runs good and we were wondering about the gasoline to run in it and if it need any additives added like lead or octane. I know I will have fun with this project and all the bolters out there have already helped me out a lot as I have been looking at this great site for about two months and finally decided to join and ask questions. | | |
#10030 01/10/2005 4:05 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | You know I don't think regular gas was very high octane in the 40's | | |
