4 members (Wayne67vert, Wally / Montana, moparguy, Pete1946), 130 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
#100238 04/07/2007 12:02 AM
Two years ago I purchased a wiring harness connector that is supposed to mate my 57 to a 69-74 GM steering column harness. Well, it doesn't fit. My steering column was represented as a 1970 Suburban, but it can't be. The male connector attached to the column is curved, with eight wires attached. My real need is just to know what each wire goes to. I'd gladly purchase a wiring diagram, if I knew the correct year for the column.
I have a new blank female curved connector with no wires attached, just a supply of the little pins so I can make it up.
Any suggestions from bolters ?
How are the wires marked?
I believe this is typical of GM columns:
G - single green: horn
H - double aqua: left front turn signal
J - double blue: right front turn signal
K - single purple: hazard
L - single purple: turn signal flasher
M - single yellow: left rear turn signal
N - single dark aqua: right rear turn signal
P - double white/orange: brake switch
Does that help?
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Alan--the colors in my column connector are
black
black w/lt blue stripe
dark blue
brown
violet (purple?)
black w/ yellow stripe
green
black w/ white stripe
With a library full of wiring diagrams, I could determine the year and model of the column by matching wire colors
Cletis has a great tip in Tech Tips on this. He "put my powers of reasoning and deduction to work"! Ed
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
