7 members (Hotrod Lincoln, Shade Baby, 1955 1 Series, NJC, baldeagle, tclederman, 1 invisible),
54
7
Mod | | | Forums66 Topics128,016 Posts1,055,337 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | Hi I am at the stage to replace the wiring for the lights in my 1951 chevy styleline. what gauge wiring should i use for the taililights, and headlights. I will not be adding anything extra to the car at the moment so i do not want to spend money on an aftermarket wiring harness.
Chaimv | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Chaimv, A bolter from the past...Yahoo! I have enclosed a link to a site that has all kinds of wiring info and will probably answer your question. Note the info for 6 volt systems. Good luck. http://www.crowbarelectricalparts.com/Specifications.htm Stuart | | | | | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | Thanks Automarc. Did not dispeer it was a very cold winter in ontario so i could not work on my bolt. now it BACK TO WORK  | | |
