0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Getting ready to drag the 54 out of the corner of the barn. Truck has been sitting 20+ years. Wondering if anyone has any advice regarding what I should do to the HydraMatic, besides check for fluid, prior to trying to start the truck. Truck was running when parked and trans seemed to be working ok at that time. Thanks. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 54hydramaticFL, I would just check the colour of the fluid and check for a burnt smell, and of course make sure there is an adequate amount to lube/apply everything once you get the truck running. The fluid in ideal condition will be bright red, but you should be able to see through it, hope that helps. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If the fluid looks good I would get the truck running and make sure that things get warmed up good before you try putting it in gear. Also check and make sure the level is where it should be when its warmed up. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Just as important is the engine oil. It could be in worse shape because of contaminants from exhaust blow-by and possible coolant contamination. Thick gummy oil can easily ruin a good engine by clogging up oil passages and seizing bearings and causing all kinds of problems. | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Thanks 38, Don & Lonnie for the advice. Planning to see if she'll start this weekend. | | |
