4 members (Woogeroo, klhansen, jay d, 1 invisible),
130
Mod | | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 40 | I am finally converting my 1946 3/4 ton Chevy Pickup over to 12 volt and I am trying to figure out if I need to replace my 6v light switch with a 12 v one and why...it seems to me a switch is a switch...unless it has a fuse in it. Any thought here? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you're right, the switch will be fine on 12V, there's no fuse IN it, and if there's one ON it, it'll be OK because 12V means lower amps
Bill | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | The dimmer may not work quite the same. Personally I don't dim the dash lights. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Switch rating 101. Low volts (6) equal high current to do same work. High volts (12) equal less current to do same work. Dimmer is a resistor. To dim dash lights add resistance to the circuit. Here is where we get confused. In the best of all possible worlds you would keep the switch contacts from a 6 volt for all applications. Enough current for 6 volts and a good long, as in forever, life at 12 volts. The resistor to dim the dash lights would be matched for 6 or 12 volts. Bigger resistor for 12 volts and smaller resistor for 6 volts. So I suspect the manufactures, and this just my own suspicion, make one switch with different resistors for either 6 or 12 volts. I would expect the same for Heater controls as well. And like truckernix I don't dim my dash lights either. Any one take one apart to see if they are different?
Steve H
| | | | | Joined: Dec 2011 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 40 | Thank you all for your information...This forum is why I am a stovebolter. | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Generally switches, like any electrical device, are rated for the amperage (heat) they can handle. 6v items carry twice the amperage as do 12v items of the same wattage. Therefore all your switch connections will handle 12v just fine given the same load (watts). Only if you increase the 12v wattage consumption (such as a stereo or amp) to over double the original consumption will you overload your original switch or wire. The formula is simple as pie P=IxE
Wattage(P) = Amps (I) times Volts(E) 24 watt taillight = 6 volts times 4 amps 24 watt taillight = 12 volts times 2 amps
If you are considering fixed resistance the opposite applies. Amps will double with voltage.
Sorry if this reply is winded.
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | For those not comfortable with electricity. I have found this to be helpful: Think water! OK, now, Volts is like pressure. Current is like volume. Resistance is like a kinked hose. Little kink is like a small resistor, tighter kink is like a bigger resistor. Watts? Like how much work can be done. Big hose=big volume=big wire and of course a little AWG number. Little hose= little wire and a big AWG number. AWG? American Wire Gauge. Current and Amps are the same thing. And yes all these things are related to each other. That is why the P=I times E thing works. P is Watts is work. I is current is amps is volume. E is Volts is pressure. And if you need to know E is "electromotive" force. Is this helpful? Smile and enjoy. Some one will want to talk about BMEP and Volume metric efficiency some day soon. Then some one else will have the information and I will get to listen.
Steve H
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | For those not comfortable with electricity. I have found this to be helpful: Think water! OK, now, Volts is like pressure. Current is like volume. Resistance is like a kinked hose. Little kink is like a small resistor, tighter kink is like a bigger resistor. Watts? Like how much work can be done. Big hose=big volume=big wire and of course a little AWG number. Little hose= little wire and a big AWG number. AWG? American Wire Gauge. Current and Amps are the same thing. And yes all these things are related to each other. That is why the P=I times E thing works. P is Watts is work. I is current is amps is volume. E is Volts is pressure. And if you need to know E is "electromotive" force. Is this helpful? Smile and enjoy. Some one will want to talk about BMEP and Volume metric efficiency some day soon. Then some one else will have the information and I will get to listen. Man, I can't even understand how water works. I pay the electric bill because they send the bill. I never see the electricity. What am I paying it for? It does hurt when you touch it though.
