1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Rough day in the shop today. The harmonic balancer on my 228 does not slide onto the end of the crankshaft far enough, resulting in it being at least a fan belt width too far forward. I'm sure it will throw the belt when I start it up. How can I tell if this is the correct balancer for my truck? An alternate question is this: is it possible that the timing gear is incorrect? When I install the balancer it hits the timing gear. Any suggestions would be appreciated.
Neil 1940 GMC 1/2 Ton
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Update: I had our machine shop at work take off 7/16" of the rear sleeve on the balancer. That seems to have done the trick, as it now goes on just enough for the pulley to line up with the pulleys on the water pump and the generator. Still not sure why it was the way it was. And hopefully I didn't just screw the pooch by shortening the rear sleeve.
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Has the engine been assembled for a while, or has it been rebuilt recently? I think I would have investigated things a little further by dropping the oil pan and looking at the position of the timing gear before doing a butcher job on the balancer. Jerry
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Yeah I agree with Hotrod on the further inspection before modifying anything. The timing gear could have easily walked forward, and now if there is a gap between it and the crank, it can always move back, or worse yet come off completely. This could have been one of those red flag moments that needs further investigation.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Rebuilt about 5 years ago but hasn't been started yet. Trying to get things together to start it up and get the truck on the road. So no, it's not been run since rebuild. Looks like I'll take my chances at this point. Funny how I post a question before I do anything and get no responses in over a week. Lots of looks, though. Then as soon as I give an update on what's already been done I get all kinds of great advice.
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | There wasn't much info given in the beginning post to offer much of a response. Seeing now that your saying its a newly rebuilt engine, I would say your crank gear is either on backwards and not allowing the gear to seat flushly against the main journal(that would be about the same amount you had to cut off of the balancer), or the gear simply wasn't all the way on, even if it was not on backwards. Check that first.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | If that damper is the correct factory part, it was a huge mistake, machining it off. The problem is with something else, like others here have mentioned. You should have asked here first for some dimensions.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Well, what's done is done I guess. I apologize if I came across a little short yesterday (no pun intended). Just frustrated. Thanks for the input guys. I'll have to do some work to find out what really happened. In the meantime, anyone have a harmonic balancer for a 228?
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | If you've got the ability to cut it off, you can also make a spacer to correct the problem. Just be sure to drill and tap the end of the crankshaft and use a Grade 8 bolt to secure the spaced-out balancer, because you've lost part of the press fit that would normally be holding it on. Machine a ring the same thickness as the cut you just made, and once the timing gear is on right, sandwich the spacer between the timing gear and the balancer. Use some blue Loctite on the center bolt and torque it to 55-60 ft/lbs. if it's a 7/16" diameter bolt. Jerry
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Sounds like a plan Jerry. Thanks for the advice.
