3 members (55shaker, Bill Hanlon, 1 invisible),
54
Mod | | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 31 Apprentice | | Apprentice Joined: Sep 2004 Posts: 31 | I've converted my 54 to 12 volt with alt. Battery goes down after long sits. Current tester shows current until I pull the DA plug. It is a small current but it does take the battery down over time. Is there a way to stop the back flow? DA plug was replaced and is ok. Do I put large diode on charge cable coming off of alt.? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | lutrexen,
I would guess you have a failed component in your alternator. The diode deal you are probably thinking of is to prevent engine run on when the #1 wire is wired in such a way as to feed the coil after the key is turned off. Yours is a different animal..a diode inside the alternator has failed.
Stuart | | |
