2 members (Scott '48 2ton, dgrinnan), 141 guests, and 2 robots.
Topics128,163
Posts1,056,962
Members48,458
#100168 04/03/2007 8:02 PM
I'm new to the old truck bug, but I've been bitten hard. My question is this. What's the difference between a regulator and an alternator? Which is better and why? I recently bought a '55 235 for my '49 3600 and I think someone said these were 12 volt, but I'm not sure. I want to deep the truck stock appearing, but I would like some modern upgrades (i.e. wipers, radio, etc.) which route should I take for this? Thanks for any help.
If you think you can't, you're right. If you think you can, you're right.
#100169 04/03/2007 8:18 PM
An alternator produces electricity and a regulator regulates the amount of electricity it produces.
Which is better and why? I don't understand your question. They are used in conjunction with one another.
Whether the '55 engine is 12V depends on if it was from a car or a first series or second series truck.
Your truck can easily be converted to 12V if you want 12V wipers and radio. You can use either an alternator or generator. A generator will be fine with just those accesories. If you go to adding things like A/C, power seats/windows and the like, go with an alternator.
#100170 04/03/2007 8:36 PM
My bad, I meant the difference between an alternator and a generator. The motor is from a '55 car that had a powerglide so it should have the hydraulic lifters, if I remember right. I only plan on the wipers and a radio. They didn't make trucks with A/C back then, so it seems kinda silly to spoil the whole point of an old truck by adding the A/C. Thant's what the big glass things on the doors are for of you get hot, right?
#100171 04/03/2007 8:52 PM
the 55 woulda been 12V, and a generator will have no problems running any accessories you might have, as they did in the day, the main advantage to an alternator is lots less maintainence
#100172 04/03/2007 10:25 PM
Riding in the Passing Lane
The motor will have 12 volt gen. & coil. The original 49 is 6 volt. If you use the 12 volt system (preferred) you will need to convert rest of the system. The gen is more original but the alt charges at a lower RPM & is more reliable. The alt is a good idea if you will be in parades or heavy traffic.
1972 Chevy c10 Cheyenne Super
