9 members (JoergK., klhansen, Hotrod Lincoln, Stovebolt48, 1955 1 Series, Bill Hanlon, fonz8261, latroca52, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 22 | This is my first post in the electrical bay. We , my ten year son and an occasional friend, are swapping out a tired 235 for a newer stronger model. I know that I will need a new wiring harness and have no idea where to start. I hope to start posting pictures next week. Any suggestions, hints, advice?? All suggestions are appreciated cause I'm a total novice amateur.
Thanks in advance
Ronnie Ray 46 Chevy 3/4 ton pickup | | | | | Joined: Jan 2014 Posts: 18 New Guy | | New Guy Joined: Jan 2014 Posts: 18 | What are you swapping in? | | | | | Joined: Jul 2013 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 22 | I have a newer 235 but don't know the year | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | changing the engine won't affect the wiring, you need the standard harness for a 46, check the vendors in the Links pages, pick one that's close to where ever you are, with a good price, fly at it, if you have problems with the install someone here can help you thru
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Ronnie Ray, In addition to Bill's good advice: Two decisions/needs that you should consider: 1. Do you want original appearance wiring (braided coverings - more expensive) or modern-appearance wiring. 2. Do you want many more circuits because you are adding accessories. Jim Carter sells both kinds of wiring harnesses designed for your year. Other very good general-purpose modern-style harnesses (with fuse box/boxes) are available, but you would have to install/run wires, cut wires, and terminate ends. | | | | | Joined: Jul 2013 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 22 | Thanks for the tips. I am in the process of getting some pictures that I can post. Need to learn how to do that first. I hope to order a harness in the next couple of weeks so I can have that ready. I don't think I need the original style wiring. I like it best and saving some cash is always useful. I will probably want to add a circuit or two in the future
Thanks again
Ronnie Ray | | |
