3 members (klhansen, TUTS 59, 1 invisible),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,192 Posts1,057,355 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Hello,
What Year did Chevy/GMC trucks move the clutch/brake pedals from coming through the floor to hanging from under dash?
Thanks, | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I have a 59 they are thru the floor, i think in 60/61 they were hanging.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | 1960 was the first year hanging from the firewall/ dash. Up through 59 they came up through the floor. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | That is interesting, I believe on the 1954 Chevy car, the pedals came up through the floor. On the 1955 Chevy car the pedals are hanging from the firewall/dash. Sounds like the Chevy truck engineering department was lagging behind the car engineering department. According to your reply the truck clutch/brake pedals did not transition from floor to firewall/dash until 1960, where as the car transitioned from floor to firewall/dash in 1955. It took the Chevy truck engineering department 5 years to get on the firewall/dash band wagon. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | That is interesting, I believe on the 1954 Chevy car, the pedals came up through the floor. On the 1955 Chevy car the pedals are hanging from the firewall/dash. Sounds like the Chevy truck engineering department was lagging behind the car engineering department. According to your reply the truck clutch/brake pedals did not transition from floor to firewall/dash until 1960, where as the car transitioned from floor to firewall/dash in 1955. It took the Chevy truck engineering department 5 years to get on the firewall/dash band wagon. This doesn't mean the truck engineering department was "lagging behind". There could be several reasons for this. Foremost is probably that it was easier to access on a truck than a car below the floor, and it was unnecessary to change until 1960. That's my guess. Most of the time when these changes weren't implemented it was a business/cost decision. Remember that trucks used to be purely workhorses. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Foremost is probably that it was easier to access on a truck than a car below the floor, and it was unnecessary to change until 1960. That's my guess. That is a good point, but the truck body design changed with the 1955 2nd series truck, but they still kept the same floor pedals as in the 1947-55 1st series trucks. In 1955 the car body design changed, at that time they also changed the pedals from floor to firewall/dash. Body design change in the truck did not effect pedal location but it did in the car. | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Yeah the 59's down you can take the body off and still drive the frame, as it is all pretty much self contained.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's it right there, Drivable Chassis. Basically, it makes it easier to adapt the bare truck chassis to different bodies without having to worry about pedal mounting. It's also the reason that the solid steering column was used through '59.
Bill Burmeister | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think they took longer to move to the key starter on the trucks too. Did the electric wipers appear earlier on the car? | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Did the electric wipers appear earlier on the car? According to the 1929-1957 Master Parts Catalog MPC. Chevrolet passenger car electric wipers did not appear until 1955. Group number 10.150 Motor and Parts Windshield WiperChevrolet Truck electric wipers did not appear until 1954. Regular Production Option RPO 320 Group number 16.064 Motor-Housing-Screw-Switch-Windshield WiperI guess you could say a Chevrolet Truck electric wiper motor was offered 1 year before the Chevrolet Passenger car. One-up for the Chevrolet Truck Engineering Department! | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Another observation about the 1954-1955 1st series Chevrolet truck electric windshield wiper motor. Is that it would be the only 6 volt electric windshield wiper motor that Chevrolet ever made. In 1955 the Chevrolet passenger car and the 1955 2nd series truck electrical systems were upgraded to 12 volts. Prior to that Chevrolet cars & trucks electrical systems were 6 volts. That's if the above information holds true. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I wonder if anybody has those original early electric wipers on their truck. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have the 6V '54 motor on my burb. I used a Ron Francis VR-4 voltage reducer to power it. | | |
