8 members (32Fordpuchoptop, 3B, TUTS 59, Shardean, msmall, carbking, Bill Hanlon, FrankenChevy),
56
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | if a vehicle has the clear coat peeling off on a large section of vehicle can it be re sprayed with clear coat or does it require total paint removal and redone
thanks Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | trouble with the once it's failed thing is the base coat is no longer protected so "what's happened to it in the mean time?" has already begun... will it fail under the fresh CC ????
It's as easy to take off both as it is just the CC. A razor blade and a heat gun will take most of it off about as quick as anything and it's cheap and relatively dust free and.... quiet. (I don't suggest this for old original type paint but I find the BC/CC is easier)
| | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Strip it down & re do it. This is usually caused by the sun, due to not enough mils in the clear, which means the clear coat is too thin. Common causes are not enough coats, or too much material was removed from sanding & buffing. It's always good practice to put on an extra coat, if you are planning on doing excessive buffing. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Someone told me that you do a minimum of 7 coats of clear because 3 or 4 or them will be sanded off during the wet sanding process. When you understand mil thickness, that makes sense. Then not to mention all the buffing and waxing you will do over the years. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Clear coat eventually fails regardless of thickness. If you catch it early enough and the base coat is a solid color, you theoretically can sand off just the clear and reshoot it over the existing base coat. But, it is hard to do without sanding through the base coat. If the base coat is metallic, you have to reapply both base and clear as sanding metallic base coat ruins it (you sand partially into the metal flakes which changes the look).
If the clear has just failed in a localized area, and the base is a solid color, you can spot repair the clear by sanding/feathering the failed area and applying clear to nearest panel break. If base color is metallic, you will need to blend the base/clear repair.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Since the OP doesn't mention the vehicle in question I'll add that CC from many car makers during the 80's was prone to failure anyway. Not enough UV protection I believe. Modern CC is a different animal (good one's not cheap ones...)
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I did a quick search for 90's era Tbird paint failures and it isn't pretty... I agree with the advice I found that say's strip it down to factory primer do your prep then Sealer coat color coat CC
