0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 13 New Guy | | New Guy Joined: Sep 2013 Posts: 13 | I scored a Chevy 250 six cylinder out of a 72 pickup on Craigslist. It runs good and came with a three speed manual tranny. I plan on rebuilding it and putting it in my 38 series TD.
Any tips on fabricating motor mounts would be appreciated.
1938 Chevrolet Series TD 1 1/2 Ton
| | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | This doesn't address fabricating mounts but I have a question: if your engine "runs good" why rebuild it? | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | For the cost of a tow (AAA will not touch antique/classic vehicles) a look at the internals is cheap insurance. If you run antique/classic insurance, you can add towing packages (I have basic towing for $9/year for 3 incidents, up to $100 per incident) but there are limitations. And $100 towing doesn't get you far.
Most charge $75 just to answer the phone.
I'd at least check compression and bearings, and look in the oil pan as a minimum before putting a 'running' motor (off CL) into a driver.
| | | | | Joined: Sep 2013 Posts: 13 New Guy | | New Guy Joined: Sep 2013 Posts: 13 | A $300 rebuild kit and a couple of hundred in machine shop work is cheap insurance to me. The motor ran ok but it has a lot if miles on it. It is caked in oil and dirt. Plus fresh bearings, pistons, rings, etc will make it reliable as a driver. And I plan on putting a CL turbo 350 automatic behind it.
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | You might get a good idea if its even worth the trip to the shop by doing a dye penetrant test. Most welding stores have a kit for about $50.
If the block is dirty, then it won't help.
A poor mans test is to use kero and talc to find cracks.
$300 for a flux/clean/pressure test and measuring journals is very cheap insurance. | | |
