1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
How thick are the isolator pads (the flat ones) on the 41 thru 46 cab mounts? Thanks, Scott
I'll be at my shop tomorrow and measure mine if you would like. I got all of mine new with the kit. I'm guessing 1/4" but will measure if you like. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
That would be great. I'm thinking I will make my own kit, but don't have any samples of the original pads. Also what keeps them from turning and getting cockeyed over time? Thanks Scott
I don't know the specific part, but would the pressure between the cab and the mount not keep them in place?
My 46 GMC on Photobucket
I don't know if they will move or not, but since they sit on the frame with only one bolt each, and the rear 4 cab mount bolts are spring loaded I suspect there is the potential for that. I'm just wondering if that is an issue anyone has encountered. Scott
better question Scott, is why would the [bolted] pads moving be an "issue"? if they did happen to turn they would still be "isolating" metal from metal, they can't get lost
I guess I'm just anal. I suppose I could just make 2 long ones then it won't be an issue. I didn't think of that before. LOL! Scott
Sorry I didn't get back, I keep forgetting. The thickness is .180 I tried to measure an old one but could not find one in an easy place to measure it. Dave
1941 Chevy
