1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1001058 01/22/2014 6:35 AM
I'm restoring my 1953 chevy truck and I'm looking to get a wiring harness from classic parts America or Jim Carter's is safe to use the same style wiring or should I use a modern harness with a fuse box ?
Original style wiring was quite safe.
Classic Parts and Jim Carter wiring is quite safe, when properly installed using original style fuses/breakers/switches.
Are they hard to install ?
No. They are pretty easy to install.
Mitch
the one thing i was concern about is that the original didnt have any fuses box .I wont be running anything extra except the original heater and maybe a 12v wiper motor..
sal moreno #1001167 01/22/2014 10:06 PM
Sal, the original electrical accessories used inline fuses, which work fine and are available from your local parts stores
Flxible #1001195 01/22/2014 11:45 PM
Ok thx bill I will order one from classic parts of america..
Sal,
"the one thing i was concern about is that the original didnt have any fuses box "
There was a two-fuse fuse box on the firewall of a 1953 truck.
Depending on the light switch you have, it might have a fused circuit on it and/or a circuit breaker in the switch.
Bill has explained that accessories might have had their own in-line fuse. Wiring for most accessories is not included in that kit (wiring for dual signal lamps is included).
