8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I'm restoring my 1953 chevy truck and I'm looking to get a wiring harness from classic parts America or Jim Carter's is safe to use the same style wiring or should I use a modern harness with a fuse box ? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Original style wiring was quite safe.
Classic Parts and Jim Carter wiring is quite safe, when properly installed using original style fuses/breakers/switches.
| | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Are they hard to install ? | | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | No. They are pretty easy to install.
Mitch | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | the one thing i was concern about is that the original didnt have any fuses box .I wont be running anything extra except the original heater and maybe a 12v wiper motor.. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Sal, the original electrical accessories used inline fuses, which work fine and are available from your local parts stores
Bill | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Ok thx bill I will order one from classic parts of america.. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sal,
"the one thing i was concern about is that the original didnt have any fuses box "
There was a two-fuse fuse box on the firewall of a 1953 truck.
Depending on the light switch you have, it might have a fused circuit on it and/or a circuit breaker in the switch.
Bill has explained that accessories might have had their own in-line fuse. Wiring for most accessories is not included in that kit (wiring for dual signal lamps is included).
