| | | Forums66 Topics128,101 Posts1,056,518 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | I'm putting together a 3600 frame that has been converted to the newer tie rod ends and the boots are dry rotted.
Any idea where replacement rubber boots may be available? | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | NAPA has them. Not expensive as I recall.
Steve H
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Thanks...NAPA down there is not like NAPA up here unfortunately, about 1/10 the selection, sorta like comparing Can and US Netflix..
I will check with them tomorrow tho. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | I have looked at NAPA online then take the P/N to the local for the younger "it ain't" in my computer types..just a thought.
Steve H
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | All auto parts stores have grease boots of various sizes, in the HELP section. Take an original with you to get the proper size.
