5 members (Otto Skorzeny, Cosmo, TUTS 59, tclederman, Wayne67vert), 71 guests, and 3 robots.
Topics128,179
Posts1,057,130
Members48,463
i ordered a set of these http://www.napaonline.com/Catalog/C...-Cylinder-Kit-Rear/_/R-UBP147_0230504014 and the set doesn't look like the old stuff that came out of my wheel cylinder,did i get the wrong set or how do i put this set in?
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
3B Offline
Hy Materman, am I correct in assuming that you wanted solid cups and not ring type cups? If so you should have ordered kit UP204, or you could order UP725 that is the solid 1 1/2" cup, just order as many as you need. In the paper catalog is a little note beside the UP147, "contains ring type cups, for solid cups use UP204", hope that helps.
thanks, i couldn't find those part numbers
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
i cant seem to find up204 at napa, though
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
3B Offline
Hy Materman, you don't actually want to order the kit, the kit you already have with the ring type cups contains the same boots as the UP204 would, so all you need to order are as many UP725 cups as you need, I'll look on the Napa site and see why you can't find UP204
3B Offline
Hy Materman, it looks like the part number has been changed for some reason, the 1 1/2" solid cup kit is Napa p/n UP195, hope that helps.
thanks, what about the spring in my kit? will it work still?
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
3B Offline
Hy Materman, if your original springs are not re-useable then you better order the UP195 kits and return the original UP147 kits you ordered, hope that helps.
thanks, i'll look into that.
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
