Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#1000811 01/21/2014 3:13 PM
My accelerator pumps leak. Is there a trick to stopping this? Adhesive or something on the gaskets? What have you guys tried? I have dual holly 780's.
Thanks.
Hollow65 #1000835 01/21/2014 4:23 PM
Riding in the Passing Lane
The diaphragm is ruptured or the cover is warped.
1972 Chevy c10 Cheyenne Super
Hollow65 #1000846 01/21/2014 4:44 PM
ojh Offline
The accelerator pump leak is usually where the bowl mates to the metering block. There is a small hole for the accelerator pump shot and the back pressure from small squirters will push a very small amount of fuel out past the gasket, this is directly above the accelerator pump and everybody blames the pump gasket.
A shop is where you wash your hands before you pee.
