| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10007 08/06/2003 3:41 AM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Ok folks, I admit it, I'm a basic wrench-turner. In an earlier post, I asked a question that involved timing. I was advised to check both my mechanical and electrical timing. Now I just disconnect the Vac, and turn the Dist to set timing. Can someone please explain the differance? And Don't Let My Wife See This Post! She thinks I know everything about this ol' truck, and I don't want her to lose her innocence!
35 + years of rollin' steel!
#10008 08/06/2003 3:03 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | In the base of your distributor is the mechanical advance. It consists of two centrifugally operated weights with springs. As the reveolutions of the distributor increase, your advance curve changes. The only adjustment on this is to replace the weights and springs. Here's a good link on what to do. Ignition timing explained
Fred 52 3600 69 C-10
#10009 08/06/2003 5:10 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Disconnect the vac advance line at the carb and take a small piece of rubber hose with a bolt stuck in one end to plug the carb. This way you know that only the mechanical advance or baseline timing will be set. I would suggest If you haven't yet done a search on this web site for "ignition timing" set the search to all fields. There is a wealth of info here to walk you thru this very important procedure. Remember we are here for you if you get stuck. T
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
