7 members (baldeagle, Hush, mick53, Southerntruck, SmalltownTRKGuy, Hotrod Lincoln, Gray_Ghost),
102
15
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 4 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 4 | I have been a casual observer on the site, but have started disassembly of my 41 1/2ton. I am stumped on how to remove the cap off of the vacuum wiper motor shaft. I believe there is some type of pin holding it on. Is there a trick on getting this cap off so I can remove the motor?
| | | | | Joined: Oct 2009 Posts: 4 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 4 | Tony, Thanks. I was able to get it out yesterday. Mine looks a bit different than the one in your picture.
Josh | | |
