A quick call to quick performance wouldnt hurt unless you want to keep stock. Talk with Brydon. He is amazing with building a rear to suit you. I got this for my 1958 chevy 1/2
$680 - 9" Housing/Axle Package (58 Chevy Truck - Leaf Spring - Custom)
- New Axles, Axle Bearings, Wheel Studs, & Retainers
- 31 Spline, Choice of Bolt Pattern, 1/2" Studs
$820 - Center Section (Assembled)
- New 31 Spline Trac-Lock Posi
- New Motive Performance Gears (Choice of Ratio)
- New Timken USA Bearings
Disc brakes -Wilwood
Taxes in I was in for about 1800.00-2000.00. His perchs are spot on. Bolted right in with a 1330 series yoke.
Not saying do this but its a good option for you. Sure beats a 4000.00 12 bolt gm Moser rear
