Jerry,
Just so I know--does that mean if you jack up both wheels and turn the driveshaft then the wheel should go around 4 turns + a little (4:11) like it would if you where going down the road.
I will give it a try but also trying to take the back cover off to see if I can see the stamped #s on the ring gear.
Rodger
