| | | Forums66 Topics128,290 Posts1,058,562 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,786 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,786 | They should do fine on a 261 unless it is a dedicated race engine; in which case they may be a tad small. But if you are not at continuous WOT they should be fine. You will probably have to do a little tuning for the 261.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
