I personally think it's silly to wire it up for 'split shifting'. Wire it like a factory set-up and use it like it was meant to be used.
Also the SM319 is a Saginaw transmission with a Borg-Warner overdrive unit mated to it. You will need the side cover from your SM318 3 speed.
