0 members (),
67
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Water works just fine for a leak test and to see if the thermostat is good. Just drain it out when you are done. It will freeze. Water is my choice just because it won't hurt the environment if it does leak and...it is cheap. But don't forget to drain it out when the test run is over. Antifreeze will help protect the water pump and it it is better at heat transfer than plain water. Also will provide some corrosion protection with the different materials encountered. Did I mention the thing about freezing? Yes use water just don't forget to drain and replace.
Steve H
