"Backfiring through the carb" tells me the distributor is 180 degrees off.
~ Victor
1941 3/4-Ton Pickup (in process). Read about it
in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD
1957 3100 - moved on
1959 C4500 Short Bus "Magic Bus" - moved on
1959 G3800 1 Ton Dually "Chief" - moved on
1958 C4400 Viking "Thor" ~
moved on to fellow Bolter
