The pinion being offset some is not a problem at all. The driveshaft will be fine if not parallel to the truck centerline. Here's a tech tip with resources explaining driveline setup, how to measure the compound angle, and how to figure the U-joint operating angle.
http://www.stovebolt.com/techtips/driveline/setup/index.html
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
