| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Tremec also makes the TKO 5 speed rated at 600 ft. lb. But unless you have done quite a bit to get power to the pavement or put a load of dirt in it, I wouldn't think a T5 would be a problem either. Check them out at SummitRacing.com
Dennis
40 Chevy 1/2 ton
