0 members (),
100
Mod | | | Forums66 Topics128,261 Posts1,058,346 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | The problems I've encountered with coilovers in general involve putting ssuspension loads on areas not engineered as weight-carrying points. A shock absorber mount is designed to mainly withstand a pull, not a push as a spring-assisted shock will give. Shocks are usually intended to compress easily, then resist the rebound of the spring. I'm pretty sure you'll need to do some serious re-engineering of the shock mounts, top and bottom, to avoid damaging those areas when you start using them as weight-bearing points. Jerry
