0 members (),
129
3
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | To remove drum, 3 fairly long pry bars and a BFH, Beat on the edge of drum on outside, Insert one pry bar at approx 2:00 O'clock position, one at about 6:00 and third at about 2:00 Beat some more on drum and drive in pry bars, beat some more, drive in bars, You should see some movement,if yes, keep at it. If not remove brake cylinded ffrom rear of backing plate this should get you some movement.report back here with progress or fail report. We will assist you further if you experience a Fail. Good luck, Jerry DO NOT DESTROY the drum, They are as scarce as hens teeth. Jerry
Entire Thread
brake drum, removal tip, wanted
| mike 3800 | 12/09/2013 11:02 PM |
Re: brake drum, removal tip, wanted
| 1951Chevy1Ton | 12/10/2013 12:27 AM |
| Achipmunk | 12/10/2013 1:03 AM |
| EdPruss | 12/10/2013 5:27 PM |
| mike 3800 | 12/15/2013 1:58 AM |
| truckernix | 12/15/2013 3:10 AM |
| 1951Chevy1Ton | 12/15/2013 4:59 AM |
| Achipmunk | 12/16/2013 12:37 AM |
| 1951Chevy1Ton | 12/16/2013 1:57 AM |
| NOSbeast | 12/20/2013 12:19 PM |
| Hollow65 | 12/21/2013 1:11 AM | |
