| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi anssec66, It sounds like the truck was moved with the transmission removed, the rear end may have shifted a little. So what you want to do is jack up the back of the truck so that when you put jack stands under the frame the rear wheels are clear of the ground and the rear end is free to move side to side. There are bushings in the springs and they may be worn.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
