| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | If you have not done a R&P before this should not be your first one. I'll explain a little more. Be it on this rear end or one out of a Mustang you have to get everything set correctly. This is a must. Correct pinion depth, correct ring gear location, etc. If your going to try it for the first time.... Try it something that parts are cheap and available for. Not a 63 year old heavy duty truck!
I have done around 6 R&P's in the last 15 years. It always takes a lot more time than I think. I can imagine that there are enough big truck shops in California that could handle this job and take the worry out of your head as to if it is done correctly. | | |
